Salta al contenuto principale
MacBook air (mid 2009) beeps every five seconds after keyboard connect
Hi!
So, I was trying to fix a mid 2009 (A1304) macbook air and concluded the keyboard was probably broken. So, I disconnected the ribbon cable for the keyboard and started the macbook using the power pads, and it worked!
Genius as I am, I (let’s say accidentally) reconnected the keyboard ribbon connector while the computer was booting. After that, it will only give me a beep every five seconds.
Now, I know this is stating there is a ram problem, but since the ram on a macbook air is soldered onto the logic board… does this mean this macbook air is probably fried?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Ouch! Not good!
Yes you do need to make sure things are off before connecting or reconnecting things. Time for a new logic board sorry ;-{
Punteggio 1
1 Commento:
If that's the case, it's time for the trashcan
da
Aggiungi la tua risposta
Timbobs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 56
