Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
3gs screen won't turn on at all
hi everyone, so my iphone touch screen wasnt working unless i apply some pressure on the top of the screen, so i opened the iphone to see if there was any loose connections, there was a loose connection, when i was reassembling the phone the number 1 connector snapped out and the screen turned off, then i reconnected it and it worked again, then when i was reassembling it, it snapped out again, but this time i cldnt make it work again, i tried hard resetting and disconecting the board from the battery, but with no luck, it can connect to itunes i can hear sounds the vibrate button works, but it doesnt show as a camera on the computer, what shld i do plz help ty in advance :)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Try taking board out for an hour. Then reassemble. Make sure all display (1,2 &3) connections are clean/undamaged and secure( I know you said you took board off battery.. I think it's a temperature thing for th reset) try a restore.. The reset... Home and power usually works if it doesn't then I'd buy a new LCD.
Punteggio 1
1 Commento:
Keep iPhone 3GS OFF when doing repairs or you risk damaging the LCD display or Logic Board Controllers of LCD display.
da
Aggiungi la tua risposta
Ram015 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,475
