Can see just a littlebit when I shine a light on the screen
I have philips 55pus6301 and I can see just a littlebit when I shine a light on the screen. What to do?
Questa è una buona domanda?
fossdal86 remove the back cover from your TV. Check the power board. Use a multimeter to measure the outputs from the power board to a. the mainboard and b. the LED’s. LEt us know what voltages you get. It is possible that this is a power board issue for not supplying proper voltages to the backlight LED’s or that it is the backlight array which has failed. The least likely possibility is the main board not “telling” the power board to turn the backlight on. Post some good pictures of your boards with your question so that we can see what you see. Aggiungere immagini ad una domanda
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 39
