Is the display backlight driver on the motherboard or in the display
I have a Macbook Pro mid-2009 15”. My question is this:
Where is the cicuitry that drives the backlight display located? Is it somewhere on the main board (logic board, motherboard), or is it on (or in) the display in the back case?
The background to the problem is as follows:
Basic symptoms:
After the Macboook has been running for about 5 minutes, with the display near full brightness, the backlight suddenly goes off. If I hold a flashlight within a centimetre or so of the display I can see that information is still being displayed on it, but it is exceptionally difficult to read without a backlight.
Operating condition 1)
If I turn on the Macbook and the display is set to about 90% brightness or higher, the display backlight suddenly turns off after about 5 minutes or less. If I turn off the Macbook for about 10 minutes and turn it on again, the display comes on again, but goes off again spontaneously after about 5 minutes.
Operating condition 2)
If I have the display set at a lower brightness, about 75% brightness, the display runs for a little longer, about 10 minutes, before it goes off spontaneously. And if I leave the Macbook turned off for about 10 minutes and turn it on again the display backlight comes on again and the display works properly until the backlight suddenly turns off after about 10 minutes or so.
Operating condition 3)
If I have the display set to about 50% brightness or less, the display runs properly for at least 10-12 hours and the display backlight does NOT turn off.
My conclusions:
I assume that the backlight driver circuitry is overheating and turning itself off temporarily until it cools down. I have encountered similar behaviour in electronic circuits that are near failure). I also assume that it is very expensive to fix the backlight circuit and probably not worth doing for a 2009 Macbook that has a couple of other issues too (broken back-case frame, and dodgy wireless).
If the backlight driver circuit is faulty, and it is located on the motherboard (logic board) I will throw the logic board away and get another one. Or if the backlight circuitry is located on, or in, the display I will throw the display away and replace it.
I have unplugged and reconnected the display cable at the motherboard to make sure it did not have a bad/dirty connection.
I don’t know exactly which motherboard model I have but it has two fans. The serial number printed on the back cover is: W89365SP7XJ, … BUT …
The serial number reported by the System Profiler is: W89266HL642
The Macbook might have the wrong back cover on it so the System Profiler number is the most trustworthy.
Serial number printed on RAM slots: W89240CGW6XNA
Can anyone tell me for sure where the driver circuitry for the display backlight is located?
And is my conclusion faulty?
Thank you
Michael Walsh
Questa è una buona domanda?
