Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
How to fix baseband error iPhone 6 but no original baseband IC
hi there
i have some problem with my current iphone 6
i already bought secondhand iphone 6 with baseband issue (no imei shown) in activation mode so it can’t be activated because no imei
now i already taken apart my phone and it has no Baseband IC (some of the solder pin are missing)
i already ask some phone repair shop that they can’t do repair because of missing baseband IC
but i’m just curious, can it be repaired ? for example buy another baseband IC and solder it to the mainboard ?
also if it can be done, are there required special tool to re-program baseband IC ?
thankyou for your answer
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Baseband chip is paired with all major chips in the phone and encrypted. It is not possible to reverse this encryption.
There are baseband EEPROM chip reprogramming processes, but that only works if good data from the EEPROM chip is read out first or damage to the data is limited and logical error recovery possible.
If the chip is missing altogether, no fix.
Punteggio 1
Aggiungi la tua risposta
Erik giovani sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,279
