Salta al contenuto principale
A bluetooth smart speaker with a touchscreen, released by Amazon in June 2017, model number MW46WB. The Echo Show features the same Alexa technology found in previous Echo devices, with a 7" display for added functionality.
7 Domande Visualizza tutte
Echo Show Speaker grille clean
Can the Echo Show (1st gen) speaker grille be removed and put back easily? Mine has playdough in it - thanks to my three year old :(
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
yes, the speaker grill is glued on and can easily be removed if done carefully. Insert a spudger or other small thin blade around the edge and pry carefully. Disassembly of the rest of the unit is not as easy. And parts are not available.
Punteggio 0
Aggiungi la tua risposta
Grayson Williams sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 168
