Salta al contenuto principale
MacBook Air models with 11" displays
990 Domande Visualizza tutte
How do I use an anti static wrist strap with a laptop?
Want to remove my motherboard.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here is ifixit’s guide on ESD:
Electrostatic Discharge
Update 1/31/20
Here’s an instructional video on using your wrist strap
https://www.youtube.com/watch?v=qOK7X4ko...
Punteggio 2
Commenti:
That doesn’t answer my question
da
Don't use one. Just reach over a touch the center screw of an electrical outlet or any metal object that grounded out and discharge yourself.
da
I don’t know what that means. Please help. Explain it like you would a two year old
da
Simply use it as you would on any other piece of electronics when you have them open. Just connect the wrist strap to any grounded object, or the ground terminal in an outlet. Make sure you are sure that it is the ground and not a hot or neutral lug if you are using an outlet. It is the bottom prong in the US (round shaped).
Punteggio 0
Commenti:
I’m sorry I don’t understand. What do I use to ground with when you have a laptop?
da
Aggiungi la tua risposta
aimee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 69
Tutti i Tempi: 1,871
