Same here, two months old. Simply recharged and pressed the sensor button and whoa....blurred screen and no response. I have found a solution that has worked both times:
1) Let the phone charge for an Hour
2) Keep cable plugged into the phone, but remove it from the computer or wall plugin.
3) Hold the Home button and right-hand side button down at the same time for like 30 seconds.
4) Your battery symbol will return. (If it doesn't, plug back in and repeat steps every 10 minutes)
5) Plug the USB connector back into the computer or wall plug.
6) Leave the phone alone to 10-15 minutes while it charges enough to turn it on.
If this doesn’t work, you could take it back to Apple and ask for help.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
Rule out parts first by replacing the screen. They are not that expansive.
da Chris Stables
