Salta al contenuto principale
Informazioni sul dispositivo e sulla riparazione per i portatili Dell XPS 13 modelli 9343 e 9350, entrambi rilasciati nel 2015.
iFixit Toolkit cannot open Dell XPS 13 9350 battery
Immagine
I have bought "iFixit Pro Tech Toolkit - Electronics, Smartphone, Computer & Tablet Repair Kit" in order to change my XPS 13 9350 battery.
I successfully open the bottom case and able to open 2 screws at the right part of the battery.
But I could not open the 2 screws on the left part of the battery (please see attached file with circle in red color). I have tried all head styles of iFixit, but none can open the screws.
Appreciate any help. Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
You don't seem to have uploaded an image so it's a little hard to tell, but according to the guide they should just be regular Phillips head screws. It's possible they got stripped if too much torque was applied, can you try uploading or linking an image again?
Punteggio 1
4 Commenti:
Uups, sorry forgot to attach the picture, thanks for remind me.
I have used all the head screw styles, but none of it match.
da
It's harder to tell for the one at the top but the bottom one is definitely stripped which is why you are probably having issues with it. But it is standard Phillips.
da
The chassis will probably flex a bit when trying to unscrew those screws so I would say put opposite pressure under the screw under the chassis with your hand and use a PH00 / J00 or larger screw tip. Smaller ones will just cause it to strip.
da
@cosmasaay - Can you take a tighter picture of the top Black screw.
It looks like a tri-point, you will likely need a Y0 or Y1 bit
da
The guide in step #7 is showing this as a small Phillips:
Sostituzione Batteria Dell XPS 13
But if it id really stuck you may have to use extractor pliers.
Screw Extracting Pliers
Immagine Pliers designed to firmly grip the heads of damaged screws. Specially designed jaws firmly grip screw heads, bolts, or nuts allowing you to twist out even the most damaged fasteners. Professional Grade tool. ESD-safe option.
Prodotto
$23.95
Punteggio 1
1 Commento:
these screws are FIRMLY Locktited in there. I can't break them loose. How do I release the Locktite?
da
Aggiungi la tua risposta
Cosmas sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 18
Tutti i Tempi: 1,015
