Salta al contenuto principale
Light blue and white striped vertical lines instead of just white
Hi all
My display has thin light blue and white striped vertical lines instead of just plain white.
It is not replicated on an external monitor though.
Sounds like a display or possibly a signal delivery error (cable) rather than the on board graphics processor.
After reading some of the replies to similar questions, I pressed each side of the iSight camera to no effect.
Is that a correct deduction?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes, your internal display has a problem. While not visible there is a logic board within the lid which converts the LVDS signal from the main logic board to the needed raster signals the LCD its self needs.
Here’s the needed part:
A1226 Santa Rosa: Matte 661-4342 & Glossy 661-4343
A1260: 661-4609 Matte & Glossy (both used the same P/N)
And here’s the guide to put it in MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Display Assembly Replacement
Punteggio 1
1 Commento:
Thanks Dan. That's very helpful. And super speedy too. :-)
da
Aggiungi la tua risposta
davidjevans sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 77
