Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
I can’t get the home button bracket screws out!
Hi,
I have repaired 2 iPhone SEs so far, and every single one I have found the two screws over the home button bracket very hard to get out. I have ripped the bracket out successfully twice, but because of the shattered screen on this one, I cannot get it out at all! The screws are also now stripped!
Any ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
On water damaged SE’s I have drilled the left screw out than covered the home button components and applied super glue to the screw on the right.
I than bend the bracket up from the left and turn the bracket hopping the right screw will come loose. If this doesn’t work I drill it out.
They are easy to drill out if you have the right tools. I use a Dremel with dentist bits. If I were you I would invest in some quality drivers for removing the screws.
Punteggio 1
2 Commenti:
I’m definitely going to hive drilling a go, however where can I get the correct type? I searched for one, but had no matches. Thank you.
da
I think I purchased mine from iPad Rehab but that was years ago.
da
Aggiungi la tua risposta
TheRe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 102
