Salta al contenuto principale
Rilasciata a novembre 2016, si caratterizza per l'aggiornamento hardware per giocare in 4K e prestazioni PSVR migliorate.
383 Domande Visualizza tutte
Ripped off power supply from motherboard. Is this fixable?
So I ripped the power supply adapter off the motherboard and I couldn’t find any other person with this type of problem. There are no soldering points, and I need to know if this is fixable or if the motherboard is just trashed. Thanks for the help!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes this can be repaired, but not easily unless you have experience. The pads must be repaired before the connector is reattached. Also, there will need to be additional support for the connector otherwise it will easily be torn off again. This is not a repair that should be attempted without prior experience. Contact a local repair show and bring along the connector and the board (in a static bag).
Dan
Punteggio 2
Aggiungi la tua risposta
Richard Chatt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 435
