Salta al contenuto principale
Lanciato a giugno 2012 / processore Core i7 con Turbo Boost / Fino a 1 GB di RAM Video DDR5
I'm Stumped! Battery is Not Charging. Power Source: Power Adapter
The MagSafe light mostly stays dark (but see below).
Here’s what I’ve tried:
  • Tried a different (known good) charger, with the same results.
  • Verified that both chargers work on another Mac. they do.
  • Checked the pins on the charger; none are stuck.
  • Checked the MagSafe plug on the Mac; it’s clean with no signs of corrosion
  • Tried several SMC resets. Sometimes (not always) the light flashes green continuously until the Mac powers on, then the light gets dimmer and goes out.
  • Disconnected and reconnected the battery.
Here’s the the AC Charger Information from both good and bad Macs
Good Mac:
Bad Mac:
Both System Info and coconutBattery report that the battery is good.I’ve run out of things to test.
Suggestions welcome!
Questa è una buona domanda?
Punteggio 0
2 Commenti
Can you post the CoconutBattery snapshot so we can see it.
da
Can you boot into MacOS or Internet Recovery? In Terminal, try running [ pmset -g batt ] and it should report the charge status of your battery. What does it say?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Thanks to @danj and @pifia for trying to help.
I tried swapping in a known-good battery, and that didn’t help, and other questions about similar symptoms focused on the DC-in board (magsafe).
Got a new DC-in board, and took apart the Mac, only to find the existing board was loose and there were several internal screws missing. Someone who didn’t know what he was doing had been screwing around in there!
Anyway, it’s possible the existing DC board was good, and re-seating it would have fixed it, but I didn’t want to chance re-assembling the whole thing and not have it work.
So I installed the new board, and that did indeed fix the problem.
Punteggio 1
1 Commento:
I had a strange series of issues not too much different than yours. In my case I had to buy a new battery and a Magsafe board. I suspect the faulty board may have cause some sort of short to stress that destroyed the battey to a poiunt that the laptop show NO recognition of it whatsoever.
da
Hey, so I spilled tea on my 2015 macbook air(13”) and had connected it to the charger after drying the liquid but obviously that was a bad idea.
I contacted apple and they told me the location of an authorized service provider near me and I took it to them for a diagnosis and repair.
They replaced the left I/O board or simply reassembled it I’m not sure and also changed the I/O flex cable.
Now before sending in my macbook I was using a third party charger and it worked just fine however I did notice one day the condition of the battery in the menu bar said ‘replace soon’ but it never interrupted my charging whatsoever.
After this repair from the authorized service provider, I noticed my charger would only charge up to a point and then it would only power my laptop and the menu bar would show ‘battery not charging’. I tried another third party charger and it charged up until 20% (from 5%) and wouldn’t charge after that.
I took it to the service provider again and they used an original magsafe charger and it charged my laptop up until 41% and it stopped charging too and was only providing power to my macbook.
What do you think the issue is here? Because many threads I’ve read said that fixing the I/O board should have helped. The service providers said it might need new batteries but my question is how was it working fine before I sent it to them.
What I think is that they didn’t do the I/O fixing properly and this issue is simply the outcome of the tea spill which hasn’t been dealt with carefully since if the I/O board and cable have been fixed the issue shouldn’t be present.
Punteggio 0
Aggiungi la tua risposta
stevenjklein sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 10,992
