Salta al contenuto principale
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
31 Domande Visualizza tutte
Where can I get a USB charging cable for this drone?
I have misplaced the USB charging cable that came with the DX-2 stunt drone. Where can I get a replacement USB charging cable for the DX-2 drone?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Did you mean the charger including cable or just the cable itself.
Chargers are available online, here’s an example. Just search for Sharper Image DX-2 drone charger to get results for suppliers that suit you.
Looking at the charger it appears that the charger cable has the standard micro USB connector, so if you have a standard mobile phone charger which has a micro USB connector plug on the cable you should be able to use it to charge the drone.
Punteggio 3
Aggiungi la tua risposta
George Riley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,146
