Salta al contenuto principale
Rilasciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
923 Domande Visualizza tutte
Face ID issues after battery replacement (move a little higher/lower)
So after replacing my battery Face ID is no longer able to register my face always saying to move the phone a little higher and then to move the phone a little lower in a loop. I believe the issue is the dot projector. Heres what i’ve tested so far:
  1. putting the original battery back in
  2. cleaning all connectors
  3. reseating back cameras
  4. taking out the sensor module containing the front camera and putting it back in
  5. reseating and cleaning everything on the sensors connected to the screen
  6. called apple support who ran diagnostics and said that they didn’t see any issues with the hardware
  7. cleaned the dot projector with isopropyl alcohol
The front camera and back cameras still work as well as the proximity sensor and ambient light sensor. I also used an old camera to see that the flood illuminator was lighting up. The only thing that refuses to light up is the dot projector. Thanks for the help!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Rewa has just recently made a video on this. It cannot be fixed by a 3rd repair. You have to go to Apple but even then they won’t work on the phone because you swapped the battery.
Punteggio 0
Commenti:
Pls share the video link
da
Here comes the latest dot projector repair technique for Face ID move iPhone a little lower/higher
iPhone XS Max Face ID non funzionante Risolto - Riparazione del proiettore di punti
Punteggio 0
Aggiungi la tua risposta
Taylor Vandenberg sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 152
Tutti i Tempi: 1,555
