Salta al contenuto principale
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3272 Domande Visualizza tutte
backsite glass broken, which parts?
iphone 4 fell on the bricks, backsite is broken i need to know which parts to buy
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Kit di riparazione batterie iPhone
Solo $29.99
Buy Now
Solo $29.99
Buy Now
1 Risposta
Soluzione Prescelta
By backsite i assume you mean "rear glass panel"? If so all you will need is a replacement rear glass panel and you are good to go. They are very easy to install as they only require the two bottom screws to be removed and voilà, you can take it straight off.
Here is the link to the part.
Here is the link to the repair manual.
Hope this helps! :)
Immagine iPhone 4 (GSM/AT&T) Blank Rear Glass Panel
Prodotto
$19,99
Punteggio 2
Commenti:
I just did this repair to mine from a panel from here at iFixit, it literally took less than 5 minutes. ;)
da
Aggiungi la tua risposta
ben sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,510
