Hi @tvandell
No indications at all when just connecting the charger to the laptop is not a good sign.
Have you proved that the adapter is OK and outputting the correct DC voltage?
The laptop should give an indication that power is connected and should start i.e. power light and fan on when Power button pressed, but will not boot all the way to an error message of “No OS found” due to missing HDD, as it will fail POST (power on self test) due to the missing RAM.
So getting an indication that power is connected to the laptop is the first step
Hopefully it may be as simple as a faulty DC-In jack.
Here’s a link to the ifixit ASUS X552LAV-BBI5N08 guides, which should help to gain access to the internal components.
Use an Ohmmeter to test the continuity of the DC-In jack though to where it plugs into the motherboard. The laptop’s battery should already be removed before using the Ohmmeter.
You have to start somewhere when tracing power problems.
If the Dc-In jack is faulty it will have to be replaced, they are not that expensive.
Here’s a link to just one supplier of the part. It is only shown to give you an idea of what it looks like and how much it costs. There are other suppliers online that may suit you better. Just search for ASUS X552LAV-BBI5N08 Dc-In jack to get results.
If the Dc-In jack tests OK then you may have to do further testing using a Voltmeter and with power connected to the motherboard.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
