My iPhone 7 wont boot
IPhone 7 wont boot had a cracked screen//homebutton i fixt both of them except when i tried to close the screen it cracked and now it doesn't boot. Any ideas how i can fix this?
Questa è una buona domanda?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 76
We will need some more information. Does the screen turn on? If so what is it doing?
da Chris Stables
nope. i tried some stuff but it still shows no sign of life
da Bertil II
Is the home button loose, can you feel a click to it? How are you powering it on?
da Brayden S
For my understanding, you broke the screen again when you were closing it? If that's the case you should try with a different screen to rule out being a screen problem. Also, make sure if you unplugged the battery that you reconnected it correctly.
da edvinramirez56
@edvinramirez56 I agree with you. Replace with a new screen and test. If the problem remains, then it might be a logic board problem. Connect the phone with DC power supply and check the boot current.
da Phryne
