Salta al contenuto principale
Anno di inizio della produzione 2002.
please identify resistor on the powerboard
Machine could not be switched on. Replaced the logic board battery, reset the PMU, did all the other tricks recommended on this site. Took the machine to pieces, got to the power board, removed the obviously faulty resistor. Having trouble identifying it since the colour bands are hard to make out, could be a browny green or a greeny brown. It could be 12 Ohms or a smaller number. Does anyone on here know the likely value of this resistor?
ETA: the colours are clear in daylight, not sure which sequence is correct though
Resistor
Powerboard
Questa è una buona domanda?
Punteggio 0
3 Commenti
A picture would be useful as there are a few resistors and capacitors on the power board Aggiungere immagini ad una domanda
da
@Folake Shoga - Really need to know where on the board it came from.
da
Thanks guys. I’ll post again after we’ve tried the fix
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Folake Shoga  that looks like a 1K ohm resistor
Punteggio 1
Aggiungi la tua risposta
Folake Shoga sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 215
