Salta al contenuto principale
Informazioni sulla riparazione di prodotti utilizzati per la salute e la cura della persona. Le riparazioni sono tendenzialmente semplici e richiedono l'uso di attrezzi comuni.
380 Domande Visualizza tutte
Silk epil 7 shaver head
The shaver head of the Silk epil 7 has a net on the top that gets damaged often. The company produces replaceable nets but I believe that if you have at least an extra net (from a previous shaver head that was replaced) it is possible to repair the part of the net that is broken. I would like to know if someone has tips on how it can be done.
I am attaching the photo
of this part.
Questa è una buona domanda?
Punteggio 0
1 Commento:
I can only offer a suggestion, the harder you push while shaving, the faster the net will get damaged, if you dont push hard enough, then you dont get a close shave. I recommend aggressive disassembly of the damaged unit to see what you need to do on another unit with a good net to see what would be required to repair one the correct way while waiting to see if somebody has done this before. Good luck.
da
Aggiungi un commento
1 Risposta
I don’t think there is any way to do that. The best thing you can do is replace that net with a new one.
Regards,
Lewis
Punteggio 0
Aggiungi la tua risposta
CATERINA AMBROSINI sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,146
