Salta al contenuto principale
Rilasciata a novembre 2016, si caratterizza per l'aggiornamento hardware per giocare in 4K e prestazioni PSVR migliorate.
384 Domande Visualizza tutte
Why is my ps4 turning off when I start a game
Earlier today I was playing fortnite because I recently wiped my ps4 because of crashing and on reddit people were telling me to and then I got off because textures weren’t loading the entire time so I went into safe mode and rebuilt data base (another suggestion by reddit users) once I was done with that it was working fine and I had the same issue with textures so I got off and now when I turn it on Netflix is only working every time I try to get on a game it starts the loading process and then the screen goes black and the light bar on the ps4 stays white for about 10 seconds turns off the ps4 and then it brings me to the screen as if I unplaced my ac power cord. This issue keeps happening and I need an answer. Please and thank u to anyone willing to help.
Questa è una buona domanda?
Punteggio 4
4 Commenti
This just happened to me how did you fix your problem
da
Same I hate this $@$*
da
Me too what the f@#$ why is this all of a sudden a &&^&^$^ thing
da
I got the same f.ckin problem dude
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
It is possible that the fans aren't working properly. Make sure no fans are blocked and if possible take a compressed air canister and use it on the fans, or just use a vacuum cleaner.
Punteggio 2
2 Commenti:
I s cleaned it yesterday and it only happens sometimes @johnodon
da
Have you replaced your power adapter (the thing that plugs into the PS4)? If this helps please mark this question Answered
da
guys forget about rebuilding your data I just tried this and it worked the first time just run your fingers through the sides of the ps4 and the back to get the dust out then just blow on the fans to make sure there’s no dust then start it up and fortnite will work
Punteggio 1
2 Commenti:
if it's the fans and dust causing the problem then how do other applications work well? I have the same problem with fortnite and i'm trying to look for answers.
da
@not75things Hey yes I’m having the same issue as well, fortnite turns off my game when I try to load it up but I can open other applications and games on my ps4 and it doesn’t turn off. did you find a solution to your problem.
da
Yup this is happening to me as well since the new update I don't know why I can play any other game perfectly fine. Grrrrr
Punteggio 0
Aggiungi la tua risposta
BrownyM16_ Gaming sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 138
Tutti i Tempi: 11,029
