Salta al contenuto principale
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Domande Visualizza tutte
Where is complete Disassembly Guide
Hi
I can't seem to find the complete disassembly guide for model A1286 - only the initial teardown...does it exist?
Questa è una buona domanda?
Punteggio 1
7 Commenti
I have a couple of the MacBook Pro's service manual but need to have at least the year for your model to see if I can help you.
da
"Complete Disassembly" isn't really a term we use around here. Depending on your specific model and needs, we can try to point you towards the correct repair guide.
da
There are 16 models in the A1286 series. If you can give us the last three figures of your serial number we can direct you to the proper guides that are available.
da
Hi
Thanks for the replies - model late 2008 -serial no. ends in Q1G0.
Thanks
da
THank you very much indeed for the tech manual.
regards
al
da
Mostra altri 2 commenti
Aggiungi un commento
2 Risposte
Apple MacBook Pro "Core 2 Duo" 2.4 15" (Unibody) Specs
Identifiers: Late 2008/Unibody - MB470LL/A - MacBookPro5,1 - A1286 - 2255
The machine I put up is a late 2008 and should be your machine. Just take a look at the guides for confirmation.
MacBook Pro 15" Unibody Late 2008 & Early 2009
Punteggio 1
Risposta Più Utile
May be this will help
Punteggio 1
Aggiungi la tua risposta
al davies sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,492
