Salta al contenuto principale
Information and repair instructions for Frigidaire Freezer
mt frigidaire upright freezer model lffh17f7hwh isn't freezing
HIGH TEMP WARNING CAME ON. THE DRAIN HOLE WAS FROZEN. I RECONNECTED DRAIN HOSE AND DEFROSTED BOTTOM ICE. FAN RUNS AND COMPRESSOR RUNS.
PLUGGED IT BACK IN AND IT WON’T COOL TO FREEZE. COOLED TO 56 DEGREES THEN WENT TO 57, THEN 56. THEN 56. I UNPLUGED IT BECAUSE i HAD TO LEAVE AND DIDN’T WANT TO HAVE A FIRE OR SOMETHING. WHAT PART IS BAD?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Start with the top three causes listed on my previous answer:
Why is my freezer not cooling?
There are about seven other possible causes that we can go to after you check the first three.
Punteggio 2
Aggiungi la tua risposta
NANCY FRANZ sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 472
