Salta al contenuto principale
Repair guides and support for your LG TV.
1351 Domande Visualizza tutte
Why is my tv in mute without the mute button on?
My tv went mute last night but I click the mute button on and off and nothing happens. It remains mute. I went to settings/soundout / it's on optical, is that correct?
Questa è una buona domanda?
Punteggio 3
6 Commenti
Norma Maldonado that depends on how and what you have connected. Let us know what your TV's model is so we can try to assist you.
da
Hi,
Do you have anything connected to the optical output port on the TV, like a soundbar or stereo receiver etc?
If nothing connected switch the TV sound setting back to TV or internal speakers or whatever is indicated for the sound to come from the TV and not an external speaker system
da
I have a 2013 non smart LG tv and it mutes itself. I notice it when I have my HDMI cord connected to my phone for 4-10 minutes
da
my tv is lg tv 55un73 and iam facing same problem when i mute iy the sound close ok for 1 minute maybe and then it self again start volume
da
again same its unmute it self in 5 seconds
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Soluzione Prescelta
  1. Open the Settings menu either by using the button on your remote or if your remote doesn't have a Settings button, press the Home/Smart button, then click the Settings icon.
  2. Navigate to the Audio/Sound menu.
  3. Choose Sound Out, then select TV Speakers.
Try this! This might help you!
Regards,
Lewis
Punteggio 2
2 Commenti:
Brilliant Xfinity had no clue but this was genius!!!! Worked first try after being mute for 3 darn days lol thank you
da
I found this to be 100% accurate. It was entirely mute I tried everything that was suggested. Thank you this works perfectly
da
Risposta Più Utile
or just try to unplug it then wait 10 seconds then plug it back
Punteggio 3
5 Commenti:
Brilliant! That actually worked. After following all the other steps found via Google, a simple restart was all it needed. Thank you!
da
It works by unplugging it but why it keeps doing it?
da
Same here.. please help to fully recover
da
I was having the same problems ty very much ☺️
da
My external speakers set on optical for sound worked great. After pushing a few buttons, The TV went into mute mode and will not come out of it for optical. It will go on using the TV in the TV sound, but it will not work with my external speakers (optical setting). The mute button just keeps popping up. It will not come out of mute. I tried the mute on the TV, the fire stick, neither work. So aggravating. Any kind words of help would be greatly appreciated. I have tried turning the TV on and off as well as the components. Didn't work. I tried changing back to TV. And then optical didn't work. TV soundworks fine, but I love my external speakers.
da
Aggiungi la tua risposta
Norma Maldonado sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 30
Ultimi 7 Giorni: 233
Ultimi 30 Giorni: 1,213
Tutti i Tempi: 54,787
