Salta al contenuto principale
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Domande Visualizza tutte
Vertical and horizontal lines on screen MacBook Air
My MacBook Air mid 2013 has vertical and horizontal lines on screen. Hardware test found no problems.
Worked ok with external display.
Questa è una buona domanda?
Punteggio 0
1 Commento
Thanks for this.
I have aan older MacBook Air: same size screen (13") , mid 2011 version; 4GB/256GB SSDMC966LL/A. This older MacBook Air is working perfectly. Does anyone know if I can change over screens i.e. fit the older MacBook Air screen to the mid-2013 version? Thanks, Ian B.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If it worked ok with an external display it may be the display itself if that’s not it could be a board level issue.
good luck on this also got any pics?
Punteggio 0
Aggiungi la tua risposta
Ian Brunton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 427
