Salta al contenuto principale
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
31 Domande Visualizza tutte
How do I replace the blades?
A blade came off and now I can't get the new replacement one on is there some kind of trick?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If there are no fasners on the blade then try seeing if the blades pull straight off the shaft from the motors?
Punteggio 0
Aggiungi la tua risposta
Jon Hodgman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,134
