Salta al contenuto principale
Modello A1419 / EMC 3070 / Metà 2017 / processori Core i5 3.4, 3.5 o 3.8 GHz o Core i7 Kaby Lake 4.2 GHz (id ImAC18,3) / Retina 5k display. Fai riferimento alle guide del modello più vecchio dell'iMac 27" Retina 5K display (fine 2014 & 2015), dato che il sistema è molto simile.
293 Domande Visualizza tutte
iMac 2017 (18.3) - Blade model : Mounting brackets needed?
I was asked the possibility to add a SSD drive to a blade only model (18.3 3.5 ghz Retina). Do I need the right and left mounting bracket to install the adaptive 3.5 to 2.5 socket ? Since it’s a blade only model, did Apple put them anyway inside ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It’s a really good question. I have a fusion, so I don’t know for sure.
You should get some on AMZ, in case, then once you' have the iMac open you’ll be able to decide to use them or return them:
https://www.amazon.com/Apple-A1311-Brack...
Also, I would recommend an adapter: https://www.amazon.com/gp/product/B01ELR...
Here is my SSD now:
Punteggio 0
1 Commento:
Samsung drive in an iMac ... edgy
da
Aggiungi la tua risposta
Seb sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 49
