Salta al contenuto principale
My old MacBook air show blue colour only.
my old macbook air show blue colour only, even if i plug it to external display, its only show white and black colour.
its that because GPU fali r smothing else?
Update (09/28/2019)
when I try to plug to externadl display its show like this
after login its, become like this
Questa è una buona domanda?
Punteggio 0
2 Commenti
Yep - Either corrosion on the LVDS connector or a damaged internal display
da
ok, thanks @danj
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
At this point you’ll need to check your logic board displays connection. The LVDS connection may have corrosion damage and/or the cable is damaged or the display its self.
I would also try an external display to see what it shows.
Follow this guide MacBook Air Models A1237 and A1304 Display Assembly Replacement to Step 3 then jump to Step 23 disconnecting the cable and inspecting the connectors for damage.
Given the age of this system it maybe time to upgrade to a newer system (used or new).
Punteggio 2
Aggiungi la tua risposta
mars erik sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 63
