Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
iPhone 7 randomly tunring of
Hi! I've got iPhone 7 which was water damaged. After battery replacement and isoprophyl cleaning it turned on, but in the general settings the battery isn't able to show condition and showing repair need. If I put the battery in other phone, it’s showing 100 % condition.
Questa è una buona domanda?
Punteggio 1
3 Commenti
What kind of "isoprophyl cleaning" was done..were all EMI shields removed previously ? Ultrasonic or hand brushing ? Was the board checked afterwords under a microscope ?
da
@arbaman hey ! It was brush cleaning. Yep, i checked it first under microscope and no suspicious things like corrosion or stuff seen. EMI taken of.
da
@jrkstbl If you want to try the fast monkey see monkey do style, replace Tristar and Tigris and cross your fingers, wish you luck ;)
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
That is the issues of BSI point.Check the middle point of the battery connector that not connect to the battery properly resions that issues.
Punteggio 1
Aggiungi la tua risposta
jrkstbl sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 38
