Salta al contenuto principale
Rilasciata a novembre 2016, si caratterizza per l'aggiornamento hardware per giocare in 4K e prestazioni PSVR migliorate.
383 Domande Visualizza tutte
Can the power supply Port on the MoBo be replaced?
I couldn't see if someone asked this already as I went digging through the questions.
But my problem is, as I was doing a normal teardown of the PS4 Pro it required to clean it, due to a bed bugs infestation.
I pulled the power supply ribbon straight up to remove it from the port, and the port came with the ribbon.
Is there anyway to readhear it to the motherboard safely with the right glue or adhesive? It was a pretty straightforward rip. I can buy a new motherboard, but I really don't want to have to.
I can take more pictures from other angles if necessary.
Thank you in advance for your time.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You need soldering experience to fix this. Just using adhesive won't work.
Punteggio 2
1 Commento:
Okay. I can solder. I just need to get a smaller solder iron. I'll see if I can find some tutorial's for the pro. Thank you for taking your time to answer.
da
Aggiungi la tua risposta
Sarah Jones sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 44
