Solution 1:
The Circuit Breaker is Weak
Over time, circuit breakers can weaken. If the circuit breaker is weak, it may trip too often, even if the amperage draw is below the limit. If you have already checked all of the potentially defective dryer components, consider having an electrician replace the circuit breaker.
Solution 2:
Heating Element
Sometimes, if the heating element fails, it shorts out against the heater housing, causing the dryer to trip the circuit breaker. To determine if the heating element is at fault, use a multimeter to test each terminal for continuity to the case. If the heating element has continuity to the case, it is shorted out. If the heating element is shorted out, replace it.
Solution 3:
Heating Element Assembly
Sometimes, if the heating element fails, it shorts out against the heater housing, causing the dryer to trip the circuit breaker. To determine if the heating element assembly is shorted out, use a multimeter to test each terminal for continuity to the case. If the heating element assembly has continuity to the case, it is shorted out. If the heating element assembly is shorted out, replace it.
Solution 4:
Drive Motor
Sometimes, when the drive motor fails, it shorts out internally, causing the dryer to trip the circuit breaker. To determine if the drive motor is at fault, use a multimeter to test it for continuity. If the motor windings are shorted out, replace the drive motor.
Solution 5:
Terminal Block
Electric dryer power cords attach to the dryer at a terminal block. If any of the wires on the terminal block are loose, they can arc and destroy part of the block. If this happens, one of the wires can short against the body of the dryer, causing the dryer to trip the breaker. This is not a common occurrence.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
mind repeating the following in English this time "Weve clea and replace the venting stuff replaced all the fuses"? sounds like an over heating issue...are you sure that all debris is has been cleared from along the discharge tube ( that means no blockages clear through to the point where the tube connects to the outside discharge?
da prop man
