Salta al contenuto principale
La versione allargata del decimo telefono di Samsung della sua serie top S, presentato nel febbraio 2019. Dotato di Android 9.0 (Pie).
My kid brother broke a pen tip inside my s10 5G microphone hole.
My family was visiting me and my kid brother asked me to play with the phone so i left it with him for the day. After he gave it back to me i saw a trail of ink around my bottom microphone and i immediately knew that he broke a pen in it. I haven't tried any method yet as the hole is too small and i'm afraid i might break the microphone. I need help as soon as possible!!!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
There’s GripStick Headphone Plug Extraction Tool for 3.5mm headphone plugs, but I’ve never seen anything smaller.
Maybe you could create a smaller version yourself?
If not, you could try putting CA glue on the end of a toothpick to extract it.
Immagine GripStick is a tool designed to easily remove broken 3.5mm headphone plugs from jacks
Prodotto
$24.99
Punteggio 0
We would probably open the phone up and try to extract the pen tip from the inside. This does cause a few problems however as it will break the factory seal limiting the water resistance “No phone is waterproof” as well as open the possibility for breaking the back glass. If you can’t get it out from the outside, this might be your only option.
Punteggio 0
Aggiungi la tua risposta
0mepai sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 366
