Salta al contenuto principale
Lanciato il 26 ottobre 2018. Modelli A1984, A2105, A2106, A2108. Disponibile in versioni GSM o CDMA / eSIM, nano-SIM o dual-SIM / 64, 128 o 256 GB / Bianco, Nero, Blu, Giallo, Corallo o Rosso.
My invert colors aren’t turning off when it says it’s off
So basically, i did nothing with my phone except watch YouTube videos. Then when I woke up I just see everything inverted colors. So I check settings to try and turn it off but it says its already off. So I was super confused. I even restarted my phone. Please someone help!
Questa è una buona domanda?
Punteggio 4
3 Commenti
Inverted screen or colour combination??
da
Both for me I don't know what to do
da
Go into your display and text size In settings and make sure your classic and there's another one both make sure both inverts are off just make sure they're both off the siri will say that they're Off but they are not so make sure they're off that should fix the problem
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
You can try to reset all settings. This resets WiFi connections,Touch id,password,etc. no important data is lost. No pictures or anything else is deleted. Only settings. This could fix a software glitch.
You can try to update the iOS as well. This can be a bug in your current iOS version.
Worse case you can factory reset the iPhone and set it up as new. This usually fixes any software issues.
Punteggio 2
Go to siri and say turn off inverted colors
(Idk if this will work I’m just trying to help)
Punteggio 0
2 Commenti:
Thank you so much, I tried everything else but nothing worked then I tried Siri and it finally worked
da
ive been having the same issue and it wont work it already “has inverted colors off”
da
Aggiungi la tua risposta
kieu nguyen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 4,467
