Are all USB C ports equal?
I heard a rumor that USB C ports on the left side had a higher data transfer and wattage rate than those on the right side. Is this true for the 2017+ models?
Questa è una buona domanda?
Yes, its true! The left side ports data rate is different than the right on the 13” models only, The 15” models appear to be the same! I’m not sure what is different within the PCH between these to explain this as both use the same PCH. The late 2018 & 2019 models use a different PCH so it makes sense they are OK!
Late-2016 MacBook Pro models vary slightly in the data speeds they provide to each Thunderbolt 3 port.
The power input or output is the same across either side. in both the 2016, 2017, 2018 & 2019 models.
References:
Thunderbolt 3 Ports on Right Side of 13-Inch MacBook Pro Have Reduced PCI Express Bandwidth
Adapters for the Thunderbolt 3 (USB-C) or USB-C port on your Mac or iPad Pro
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 44
Tutti i Tempi: 16,649
