Right corner doesn't go in alle the way?
Right corner doesn't go in alle the way, the left one does. How can i Fix this?'''
Questa è una buona domanda?
Menü
Le tue impostazioni
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus.
As glass is obviously present your best bet is to use one of the guides to remove and reinsert the screen, which I believe is the first part to remove. If you’re not concerned how it looks then just ignore it the 6 or even 6s doesn’t have any water resistance anyway. If I were to guess the cause then it’s likely due to the bendgate issue those particularly with the plus varient suffered from at launch.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 8
