Salta al contenuto principale
The Logitech M170 is a wireless mouse from Logitech. Released in 2016.
How do I change the battery of a T631 Logitech ultrathin mouse?
My ultrathin mouse battery, after a long life, is unable to hold a charge. I’ve seen replacement batteries on the web but no instructions on how to open and replace the battery. Does anyone have a step-by-step guide to replacing the battery? Thanks for your time and interest.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Hi George!
Unfortunately, we do not have a tutorial on this mouse model. :-(
However, some research I have done. It should be possible to remove both parts with a hair dryer and then with Jimmy or ifixit Opening Tool.
If you start dismantling and want to do a tutorial for that, don't hesitate to do it! ! ;-)
Immagine Handy tool for opening electronics.
Prodotto
Jimmy
$7.95
Immagine Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices.
Prodotto
iFixit Opening Tool
$5.95
Punteggio 0
Hi
you need to carefully lift off the top cover. Best heat it up front to soften the glue.
herws the full story:
https://konasci.wordpress.com/2015/08/13...
Punteggio 0
To change the battery of a Logitech T631 Ultrathin mouse, simply slide open the battery compartment on the underside, remove the old AA battery, and replace it with a new one, ensuring correct polarity.
Punteggio 0
Aggiungi la tua risposta
George Engel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,240
