Salta al contenuto principale
Repair information for graphic tablets. Graphic tablets are also known as digitizers, drawing tablets, drawing pads, digital drawing tablets, pen tablets, or digital artboards.
48 Domande Visualizza tutte
huion 1060 pro won't turn on
i just dropped my tablet and i’m worried i totally broke it. it won’t respond at all. the led light wont turn on, none of the keys register, the pen doesn’t register, and it doesn’t show up as being connected to my computer.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Sounds like the unit’s housing probably needs to be opened up and the interior inspected for damage, loose connections, cold solder joints that have cracked due to the shock of dropping it, etc. If it’s under warranty you could try claiming a repair but more than likely if there is any indication it’s been dropped, the manufacturer will not cover the repair. If you are interested in trying to repair the unit yourself you may need initially some form of “spudger” tool(s) to open the unit. This site and others like Amazon have kits, such as the following, which can be purchased.
Essential Electronics Toolkit
That all said and done, you may find it is easier and more economical in the long run to just buy a new unit. Wish I could be of more help.
Immagine Essential Electronics Toolkit
Prodotto
$29.95
Punteggio 0
Aggiungi la tua risposta
Catlyn Leonard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 897
