Salta al contenuto principale
La Nintendo DS Lite è stata rilasciata nel 2006 subentrando alla Nintendo DS. Lo smontaggio di questo dispositivo è semplice, il che ne rende facile la riparazione.
316 Domande Visualizza tutte
Domanda Chiusa
DS lite don't work after repair.
Hello,
I've repaired my DS lite (because the upper screen didn't work).
After that, I reassembled it and it doesn't work anymore (I can see the green light but it turns out one second later). I tried to tear down it a second time and reassemble again but nothing changed.
Even when I plug it to a power supply, the orange light is missing. So, do you know the problem?
Thanks for your answers.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Hi!
I had the exact same problem, i got the dsl up and running by checking all the ribon cabels. I guess they werent attached correctly. They have to be pushed all the way in. I still havent got the red light to work thoug :/
Anyone got an idea?
tnx in advance!
Punteggio 0
just try it again.. if doesn't work.. clean the ribbon tip (the copper strip at the end), with cotton buds dip in a 70% solution alcohol.. wipe it gently and then wait until it dries (about a seconds).. then put it all again..
Punteggio 0
1 Commento:
Ok, thanks. I'll check again...
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 873
