When you are running in Safe Mode you are not using the dedicated GPU instead you are using the intergraded graphics engine inside the CPU. Give your symptoms I suspect your GPU is failing or overheating.
Lets give this a try install this app TG Pro This will allow you to more effective monitor your thermal load. You will want the full version so you can gain access to the logging function. Post a snapshot of the main window manning sure all of the sensors and fan is visible for us to see how it looks when you encounter the issue Aggiungere immagini ad una domanda
If you could this new You may need to open the system up and give it a good dusting. This is not a trivial task in the newer models as you’ll ned to get this kit [prodotto collegato mancante o disabilitato: IF174-005-1] as well as the cards (2 sets) Plastic Cards and lastly this [prodotto collegato mancante o disabilitato: IF145-224-2].
Besides the tools and sundries from iFixit you’ll want to get a small soft paint brush to help loosen the dust and a can of can’ed air to blow it way.
Votato
Annulla
Punteggio
