Grinding noises when tilted
Hello, I have a Wii that makes grinding noises when it's tilted diagonally while it spins the disc. Is this normal? (when placed normally it doesn't make these sounds)
Questa è una buona domanda?
This is normal for the Wii, as well as most slot loading CD drives. The Xbox 360 was notorious for killing disks when tilted. My solution: don’t tilt the console while in use.
I'm pretty sure it didn't do this before, I must note that I've taken this apart myself two times, and I've also removed the metal plate that has the "disc sucking" mechanism as well. Just want to make sure everything is ok and I didn't mess anything up.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 49
