Salta al contenuto principale
Repair guides for the 2018 version of the Samsung Galaxy A8 Android smartphone released in January 2018.
15 Domande Visualizza tutte
My phone will charge when connected to a laptop but not to any charger
It will spam the moisture in the charging port sometimes or just not register the wall charger at all. But as soon as I plug it into my laptop while turned off it will charge just fine.
Questa è una buona domanda?
Punteggio 2
Commenti:
My phone does not recognise the wall charger. But the moment i plug it into a laptop for a second then replug into the wall charger it starts charging
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
There’s a chance that your media transfer only option is enabled. You should be able to swipe down from the top and see what method it’s using to connect via USB. Plug it into your computer and check, and change it to USB mode only if possible.
Hope this helps,
Austin
Punteggio 1
Commenti:
thank you so much, i switched to charging-only option for USB and it's charging again!
da
same problem with me… 2 days ago mobile lower potion was exposed to water… not it is not charging with charger but charging with laptop. please tell me solution?
Punteggio 0
Aggiungi la tua risposta
Jonathan Onuluk sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 124
Ultimi 30 Giorni: 460
Tutti i Tempi: 3,802
