Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
The other line doesn't hear me when I use aux headphones
This happens with all the phones I've owned, including the two I still have.
When I make/ receive a call with aux headphones, I can hear the call, but the other line doesn't. Note his doens't happen with lighting or wireless headphones. And it also happens to my LG's.
Questa è una buona domanda?
Punteggio 0
2 Commenti
try another headphone
da
I forgot to mention this happens with just about almost every single aux headphone I owned.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
As shown in the image the pin responsible for the microphone is “AUX” , you can see that the GND and AUX pins in the female and male jack are permuted because the microphone will generate the audio (your voice) current, so first try to clean up the inside and put the male jack slightly off it’s max depth, I’ll suggest that you use voice memos or any other voice recorder application.
Punteggio 1
2 Commenti:
Now that I think about it, the issue happens with the built in call app, but not with Whattsapp. I still need to scream into the phone so they can hear me.
da
@Wolfgang 847 Maybe the iPhone is detecting the microphone but he don't use it, try to call someone with your headphone and speak through the iPhone microphone, also make sure that your phone is not connected to bluetooth speakers or any other similar devices.
da
Hello
if the microphone is working with one app and not with another it could be a software issue.
I suggest that you make a back up of your phone and restore it.
one other option could be to restore the network settings only. I went for an iphone x with trouble with speaker during call and to my surprise the genious guy resets the network settings and the speakers work again…it is a easy and safe thing to try, you will loose your wifi password but nothing else.
Punteggio 0
1 Commento:
It is weird because every single phone I have owned has that issue.
da
Aggiungi la tua risposta
Wolfgang 847 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 142
