Salta al contenuto principale
Smartphone release by Sony-- also known as Sony Xperia Z1 Honami, Sony Xperia Z1 C6902/L39h, Sony Xperia Z1 C6903, Sony Xperia Z1 C6906, Sony Xperia Z1 C6943. Released in September 2013.
51 Domande Visualizza tutte
The device doesn't turn on and draws little electricity
First it began to bootloop i think and then i couldn’t turn it on at all, then i decided to flash new firmware(5.1.1 stock) i did that right i have done it many times, i supposed it was a hard brick. Then it turned on started to optimize the apps then again it shut down.
And now i can’t enter either fastboot or flashmode. When i plug it in to charge there’s only red light. I tested it and the amperage goes from 0.03A to 0.19A even if i unplug the battery.
So i assume it’s some IC chip failure.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I fixed the problem by replacing the battery!
Punteggio 0
Aggiungi la tua risposta
Angewolf sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 23
