Salta al contenuto principale
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
Why doesn't my tablet boot up?
My tablet will not charge and when I plug it in and turn it on, it just goes to the Samsung boot screen and flashed.
How can I get past this? Or get it to stop flashing. I tried the power, volume up and home button with no results. Is there something else I can try>
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like a bad battery but sometimes if the battery is too flat it will cause this.
So what I do is hold power + volume down + home until you get the text prompting you to go into download mode warning.
Leave it on that screen while plugged into charger for about 30 minutes and that will charge the battery enough to get it on if it is not turning on because it was flat.
Once it's been charged for 30 minutes press the corresponding button to reboot tablet when prompted.
If this is still no good I recommend reflashing the firmware which I will write instructions on how to later when I have time.
Punteggio 1
1 Commento:
I did as you suggested and its just flashing real fast. If I unplug it, it shuts down.
da
Aggiungi la tua risposta
Terry Hilsendager sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 240
