Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
Domanda Chiusa
Replaced iPhone 3GS digital display but still have white screen
I dropped my Iphone 3GS on the floor and the display shows a white screen. Nothing appeared wrong with the display, no cracks, etc. I replaced with a new Iphone 3GS display assembly but still shows a white screen. Is the logic board the problem?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Try a Reset, hold both Home and Power buttons until iPhone restarts on its own.
da
Aggiungi un commento
2 Risposte
Pull it apart again and make sure all connectors are tight and all the way clicked in. More often then not, they get loose when you put it back together.
Punteggio 0
This is usually a sign of a bad lcd (the screen under the glass). If you do replace it, be very gentle with the front of the screen as the liquid contained inside will hold finger pressure and it will be noticeable when re-assembled
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 874
