Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1963 Domande Visualizza tutte
Se apaga solo y se prende - Turns itself off and on
Mi iPhone 3GS se apaga y se prende solo, ya le cambie la batería por una nueva y sigue fallando, que podrá ser?
Google Translation
t turns itself off and turns on. My iPhone 3GS goes off and turns itself on, I already change the battery for a new one and it keeps failing, what could it be?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Batterie per PC portatili
Una soluzione semplice per un grande aumento di potenza.
Acquista ora
Acquista ora
1 Risposta
Risposta Più Utile
You may try a full restore with your device hoping in a simple software glitch (that will wipe your personal data). If that doesn’t help, having already replaced the battery, I’m afraid you’re done with self repair possibilities. A bootlooping iPhone may be a challenging repair even for a pro as it can be due to a number of reasons.
Punteggio 1
Aggiungi la tua risposta
Alejandro Prieto sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 8
