MacBook Pro turns off on its own and can hardly connect again.
At some point my macbook started shutting itself out. Each time with a higher frequency. He hardly ever calls. Sometimes I press the power button and after some time (60 seconds) it shows the characteristic boot sound and again it turns off.
I already tried to open it, disconnected the battery and turned it on again. Unsuccessfully
I already tried to reset the PRAM and SMC, without success as well.
Has anyone ever had a similar problem?
Questa è una buona domanda?
3 Commenti
Try running diagnostics, press and hold the D key when you restart the system. Apple introduced a bug in the updated firmware so it might not work.
da Dan
@danj Try to update the system before, because I tried to run the diagnostics and the computer shuts down in the middle of the process.
da Thomás
I have not yet succeeded in trying to discover the source of the problem. Sometimes he hangs up and does not care anymore. I can tell he tries to call, but a small noise internally and then disarms (as if it were a hd trying to call, but it has a ssd. = /
da Thomás
