Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3531 Domande Visualizza tutte
My LCD started bleeding for no reason: can I stop it/ fix it?
Today I noticed a tiny spot at the bottom left of my iphone (see img). About 1h later a second expanding stain appeared, top left (see img).. I have a few questions:
1) what could be the reason?
2) any advice to stop it from expanding? Will opening the phone make things worse or may it help?
3) is the only way to fix it an LCD replacement? If so, is this what I need to do? If not, what do I need to do?
Thanks everybody!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@athanasius
that is a bad LCD. The only way to fix it is by replacing it Sostituzione LCD e digitalizzatore iPhone 5s
  1. No idea
  2. it’ll continue. No stopping it.
Punteggio 3
2 Commenti:
Cheers for this! Do you know if I can change the lcd without changing the screen? It seems like they only sell the whole screen/LCD thingy together.
By the way, I don’t think the LCD is bad per se, it’s Apple’s original and it lasted several years (phone is old) … I guess these things just happen sometimes (to me at least!)
da
@athanasius it's your LCD that is bad. Unless you have a LCD separator, know how to use it and have done this before I suggest you change the whole display assembly. It'll be very difficult to find and LCD without the digitizer and even more difficult to separate it.
da
Aggiungi la tua risposta
Athanasius Pernath sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 821
