Salta al contenuto principale
Released May 2012, identified by model number J2011-03-US.
45 Domande Visualizza tutte
LED Flashing red when plugged in.
When charging my Big Jambox the LED ring around the power button is pulsing red. It says 3/4 battery when I press the “J” button and is still connects to my bluetooth. I cannot understand if this is a problem or not I don’t remember it flashing red before.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your battery is failing! While it still may offer enough for the amount you are using the speaker the battery will need replacing soon.
Punteggio 1
2 Commenti:
Thank you!
Any suggestions for a good replacement battery? I've found several on Amazon just not sure what I should be looking for.
da
Here's the guide to replace it Jawbone Big Jambox Battery Replacement As to who's battery I don't have any option on who's
da
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 91
Tutti i Tempi: 6,831
