MBP boots with press on any key? Can't do SMC.
Is this normal? This way it seems I can’t do an SMC, because any press on a key will start up the MacBook Pro. How do I do an SMC on this MacBook Pro?
Questa è una buona domanda?
Wherever you are in the world you should just head to Applecare, either online or in a local store. What you are experiencing is not normal at all and will most probably lead to a Mac replacement.
This is normal. The Mac is designed to auto start when you press any key.
Just hold down Shift+Option+Control when the laptop is off for 7 seconds. It will turn on. After 7 seconds keep holding the keys down and additionally press the power button (Touch ID). The laptop will turn off. Wait a few seconds then turn it on normally, and your SMC should be reset!
Ultime 24 Ore: 3
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 115
Tutti i Tempi: 10,455
